BEDRUG BTJK07F4 2007-2016 JK 4 DOOR BEDTRED FRONT LINER KIT 4 PIECE
Features- High end rugged spray in look
- Tough cushioned liner
- No sanding prepping damage installation
- Easy to install remove and clean
- 100 Percent waterproof will not mold or mildew
- Excellent heat and noise insulation
- Installs quickly no need to remove seat bracket or center console
- Includes heat shields
- 4 Piece
Specifications- Color: Charcoal
- Material: TPO Composite
- Year: 2007-2016
- Make: Jeep
- Model: Wrangler
- Weight: 28 lbs
Price: 538.61
